Tie Block Inlay
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=22936
Author:  jlneng [ Wed Jul 01, 2009 4:13 pm ]
Post subject:  Tie Block Inlay
Hello all,
Am building a Negra flamenco and want to use black buffalo horn for the nut, saddle and tie block inlay. Should look good with Black MOP buttons on the tuners. I machined the nut and saddle on a CNC. Works out pretty sweet. My question is how can I cut my buffalo horn stock into strips suitable for use as Tie block inlay strips (2mm x 2mm x 72mm or so)? I might try a fence on a band saw after reading some other posts. Or if anyones knows of a source of black bone (or other matching material) strips in a suitable size for same let me know. The center of the inlay will be ebony with some multi line purfling between the ebony and the horn. Thanks for the help! I appreciate all of the artfull knowledge here.
Author:  Alexandru Marian [ Thu Jul 02, 2009 8:56 am ]
Post subject:  Re: Tie Block Inlay
I cut my tieblock strips from thin saddle blanks using a Japanese saw. A coping saw should work too I imagine. LMI sells black horn saddle blanks, only that they are 3.9mm thick so you still have lots of sanding to do.
Author:  jlneng [ Thu Jul 02, 2009 5:41 pm ]
Thanks , I will use the Japenese saw. As usual there is no easier way. I think Black horn Tie Block inlay will look cool........
Author:  douglas ingram [ Thu Jul 02, 2009 6:53 pm ]
I've used it. It does look cool. Very cool.
Pretty sure that I used my bandsaw...
Actually, I think that I used ebony for the tie block.
